blew my motor
RE: blew my motor
Just buy a Summit block :- $499.99. Comes ready to assemble. All tolerances checked, etc. bored, honed.
Get a 306 rotating assembly:- $599---whatever, depending on forged or un-forged pistons.
And usually the rotating assembly comes with bearings, rings, etc. And then assemble it yourself.
RE: blew my motor
ORIGINAL: 88stangaruu
Unless you are going to boost or spray, hyperuetenic pistons will be better for you, they weigh less, have tighter clearences and cost less than forged...
RE: blew my motor
thanks for assuming i'm an idiot^ i'm more lazy than ignorant hence me wanting to buy an assembled shortblock but thats neither here nor there. i will be running nos so i want forged.
RE: blew my motor
Guru, I have the strong feeling that he does not have the skills or the tools to assemble an engine, If you were out looking for a short block, I would assume that you didn ot know ho to do it. If you were asking which pistons were better, then it would be a different story.
I told him first...find a re-manufactured motor, they're just as good as any short block for normal street driving, weekend bursts at the strip. You can get them from auto-zone and they're about $899.00 with a core charge, which is within his budget, and you can get a long or short block. So if his GT-40's are ok then he's set.
And anyone can do a cam change.
RE: blew my motor
RE: blew my motor
i hope you are kidding. most engine builders have well over 50 grand in tools alone. will "you" be able to build a decent motor for 1500 bucks....no. not unless you have family or a good friend that builds motors as a profession and owes you a favor. assembly alone can cost more than that from a reputable engine builder. that being said i don't know what decent means to you....
Ive also built two other motors for friends who regularly run nitrous. Im no idiot and making it sound like i dont know what im talking about or saying i dont built 'decent' motors...is an insult to me.
Assembly is free if you do it yourself. Get a torque wrench, some assembly lube and a torque spec sheet and have at it, as long as you did all the neccessary prep work before hand/ fitting rings/ etc. your good to go. As far as machine work goes, your going to have to farm that out to get it done.
