Running like crap after head/intake install
RE: Running like crap after head/intake install
same mass air and injectors it had before.
gonna re-do all the rockers tomorrow, maybe i did them too tight
and is why they are making noise.
Will vacume gauge tell me if I have a vac leak somewhere in the intake system?
how do you check to make sure distributor is in place properly
with #1 TDC?
with #1 TDC?
Yeah, if the cacuum is low, it could be attributed to a leak, or wrong timing. It should be around 18-20 inches.
The dizzy. Set it to TDC, pull the cap and see if the rotor is pointing to #1 cyl on the cap.
