Running like crap after head/intake install
Problems........
getting lot of noise from valve train, checked covers and nothing is rubbing
are stud mount rockers louder than my old pedstal mount?
idles really low, dies, backfires a little, no real power, runs rough with some vibration
no check engine light
thoughts?
time to take it to a performance specialist mechanic and have them iron out the
wrinkles of my install?
thoughts?
double checked all the vac hoses.
timing set to 10* and 39psi fuel pressure w/ vac hose diconected at idle.
wondering if i got distrib off by a tooth or something.
ORIGINAL: PRO50SC
Vacuum leaks, timing set propperly? Couple places to start.
Even though the CEL light isn't on, it will still show codes if there's a problem. Sounds like a fuel or timing related problem to me. Did you disconnect the negative battery cable for a few minutes or so and let the computer reset itself??? Is it spitting out any type of smoke???
