Flywheel Question
RE: Flywheel Question
the 28oz offset is the 1982 or 1985 or sometime along there, well before then, 302's used the 28oz. For some damn reason Ford decided to go to a 50oz after then until modern times. When you balance an engine, you need to supply a flywheel/flewplate and a damper, but they need to match up, meaning dont mix match the dampers and flywheels. If its a 28oz motor, get the 28oz flywheel and damper, if its an earlier 50oz motor get a 50oz flywheel and damper.
Good luck
Matt~
Good luck
Matt~
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
junior04
09-28-2015 10:53 AM
