Heater Core Byapss
Old 08-10-2006, 01:06 AM
slaterracing
slaterracing's Avatar
Default Heater Core Byapss
What is the best way to bypass the heater core. Mine just went out tonight it is leaking out the weep hole just below the coolent hoses. I was thinking either just put a pipe fitting into the hoses but i know they are 2 diff sizes so i have to be careful with that but also can i just loop it at the water pump?
slaterracing is offline
Old 08-10-2006, 01:10 AM
mista_bones
mista_bones's Avatar
Default RE: Heater Core Byapss
Connect the 2 heater hoses together so it makes aloop back to the engine.
mista_bones is offline
Old 08-10-2006, 02:05 AM
mrbigshot
mrbigshot's Avatar
fix it right and replace it. take car of your car.
mrbigshot is offline
Old 08-10-2006, 02:48 AM
93foxgt
93foxgt's Avatar
ORIGINAL: mrbigshot
Yeah seriously man, you'll be able to sell it more if you ever need to and you'll take pride in knowing as much as possible actually works. But if you're driving it temporarily so you can get it fixed- loop it around from either the back near the firewall or the front, I don't think it matters, and the coolant would probably stay cooler just being looped at the front.
93foxgt is offline
Old 08-10-2006, 02:54 AM
5.0 MPG
5.0 MPG's Avatar
replacing the heater core is no easy task. On top of removing half of your interior including your entire dash you need to vacate your a/c system to disconnect the box from the fire wall to even get to the campartment. If you take it anywhere to have it done prepare to spend $500-$1000 easy! Its all time. If you do it yourself your going to need a vacuum pump for the a/c system and new R134A.
If your looking for a temporary solution there is nothing wrong with bypassing it.
5.0 MPG is offline
Old 08-10-2006, 02:57 AM
primetime5.0
primetime5.0's Avatar
just because hes bypassing it now doesnt mean he isnt going to fix it, lighten up guys. I had to bypass mine at like 12 o'clock at night because it went out, how do you guys know he isnt in the same situation?
primetime5.0 is offline
Old 08-10-2006, 03:02 AM
jjbg86
jjbg86's Avatar
on my 86 the core went out and spilled all over so i conected the 2 hoses together about a month later i replaced it and let me tell u that was a job and a half like 5.0 mpg said the whole dash needs to come out
jjbg86 is offline
Old 08-10-2006, 03:07 AM
mrbigshot
mrbigshot's Avatar
if your not willing to work on it by yourself or your not willing to pay for it to be fixed than you shouldnt be driving it.
Old 08-10-2006, 03:21 AM
5.0 MPG
5.0 MPG's Avatar
ORIGINAL: mrbigshot
huh?
5.0 MPG is offline
Old 08-10-2006, 07:35 AM
blade
blade's Avatar
Heater cores can be a pain. I bought a 86 t bird with a bad heater core The first time took about a day and a half. The second time I did it in about 4 hours. I am not sure what I did because its been about 4 years since I did it but I was able to pull the half the dash back on the right side I had a friend hold it for me I squeezed in and replace the heater core. There was no damage to the dash and I was able to do it in lees than half the day. All I am saying is it might not be the right way but there are ways to cut cornners. ever since I replace that I never had trouble again with it even though I sold it about 3 years ago! Good Luck!
blade is offline
Quick Reply: Heater Core Byapss
