gauge install question!!!
hey, i really want to mount some autometer gauges in my 93 notch. i want to get the pod that mounts where dual vents are right above the a/c controls are. anyway, my question is, how hard are these to mount and hook up??? where do u hook up the wires??? what all do u have to do to mount these gauges, can somone PLEASE take me through the process when mounting these. both the a pilliar and the vent. any help would be greatly appreciated, thanks a lot!
they come with instructions.... wire the light bulb + to the dash dimmer - to ground....then the gauge to pos/ground/signal... the hard part is routing the wires.... i just did mine on the a pillar...
ok thanks for the reply, what gauges do u have, oil pressure, water temp, etc. where is that other gauge mounted beloow trhe a pillar gauges. does anyone else have any info to add?
i have electrical oil pressure, and volt (duh) meters, and a vacuum gauge in the a-pillar...i have a mecanical water temp gauge in the a/c vent.... common to all gauges you just have to wire the bulb wires together, and wire the all the gauge +/- wires together....electrical gauges just have a single wire to go to a sender, mechanical gauges have a full 270* needle sweep but have a hard (copper, nylon tube) signal line, usually with a fat bolt/nut on the end to fish through the firewall....
HIS S-197
Aug 10, 2015 05:47 PM
