Head question
he'll need a new block or fly cut pistons....he has hypo pistons now right?
so do i
ORIGINAL: 88stangaruu
sh*t i always forget that about the 185's. It'd be nice if you could get the 185's with smaller valves.
a intake is a must if you go with good quality heads....or it defeats purpose heads can pulll the air they wantto and the intake cant handle it....but with those too you will add id say 60 plus hp a lil more at fly and another 20-40 at wheels varies from engine to engine..
ORIGINAL: grabbem88
to BOUCHERMB.....what compression is your motor???....just asking cause i'm looking at a KB for my set-up,and i think i'm screwed....
1)compression is 9.7...so we'll say 10.1....and i'm not sure my rpm intake will match up?
isn't the edelbrach lower just the same as a gt-40's?...the mach1's are 10.1,and the 99,01 cobra's close to 10 also?
ORIGINAL: Jasperstang308
grabbem ur intake won't work on the kenne bell website they recommend stock or gt40 and ur cr is not boost friendly
ORIGINAL: grabbem88
went and bought mine off the shelf at local Ford dealer's performance parts shop.
they run about $1,300 + or -, and you should be able to find them in stock easy
ORIGINAL: luckythirteen13
not sure youll make 300rwhp without an intake manifold but you will be close.
if you can find some one with afr's in stock (good luck with that) buy from them. afr is on 1 month back order so it will take over a month to get the heads after your order them.
ORIGINAL: grabbem88
ORIGINAL: Asylum839
Ok i just had my 95 cobra dyno'd today
-P.
