dont understand....
ok i dont get this, sometimes my power windows/locks on my white mustang work then sometimes they dont, ive noticed if i close the driver door all the way sometimes theyll work n sometimes they wont. as long as its not closed all the way or open they always work(the pins need to be changed because there bad, but could that be why? or maybe something lose? next is the door lock worked fine on both doors then for some reason they still work just my passenger door lock wont pop up or down when i hit lock or unlock unless i move it myself but the switches work on both doors work for the driver door n my door handle int he inside of the pass door dont work anymore since it happened? any clue?
ya but why would it affect both doors? the other side panel wont work either if i close the door all the way sometimes. but as long as its not closeda ll the way or open both work but as soon as closed all the way sometimes itll work sometimes it wont.
ya but even the pass switches wont work when the driver door is closed pass or driver switches wont work. its like it stops both of them, my next question when your driving at night and you have your lights on your gauges light up, when u turn ur dimer on to make ur interior lights come on does it turn ur gauge lights off temp or do they both stay on?
and you know how when u have ur key in the ignition and u hear a ding ding ding thing? i can almost not hear mine, so wtf is it muffled or something or dunno?
i would start with drivers door wiring (the boot that connects the door to the pillar)this is were most wiring fails under all the movement
i work at a gm shop so i might be wrong but it will probably fix both doors
dont understand your secound problem
