Correct Pushrod Length
When I install my AFR 165 heads I want to be sure I use the correct length pushrod, does anyone know which tool I need to use to measure this and where I should go about buying it? Also any help with the actual procedure would be awesome. Thanks in advance!
RE: Correct Pushrod Length
Check this procedure on the valve train geometry, you could also "build" your own adjustable pushrod....
Take an old pushrod and cut it about 1 to 1.5 inches from either end. Now use a 1/4"-20 tap and tap both open ends, then simply screw in a short piece of 1/4 inch threaded rod with a few jam nuts and voila, you just saved 20+ dollars and 3-4 days on shipping time.
Yep, get or make an adjustable pushrod. Set it up so you roller tip sweeps a pattern that's centered on the valve tip. No big deal. Make sure you measure the length the way the manufacturer of where you plan to buy your rods from does.
I think you can find an all explaining article on the Comp Cams website.
junior04
09-28-2015 10:53 AM
Daddys Girls GTs
09-14-2015 08:46 PM
