Vibration at highway speeds and Idle ?'s
I only live 8 miles from work so I never get the LX out on the highway and let her legs run. So I've taken it out a few times and I get a bad vibration in 5th gear only on acceleration. As soon as I let off the gas it goes away. Could it be u joints, rearend, tranny?
Also I've just put on a new IAC and a new TPS. I'm trying to fix an dieing problem coming to a stop. Well now the last two times I have started it up I get a flickering CEL and I can here the fuel pump relay click in time with the Check engine light. After a little coaxing it straightens out and drives fine.Does anyone have any ideas? Is it taking the ECM a little while to adjust to the new parts?
Thanks for the replys in advance!
Roger
Roger
