starting problem
once in a while when i start my 90 5.0 it will crank over try to start then stall out...then ill try again n it will turn over for about 3 sec n then fire up some times real low then idol up n some times high then idol down...but wen it does this it smokes from the exhaust wen it starts...
it has a new motor in it with 3300 miles on it so i dont understand y it is doin this..could it b not enough air or fuel gettin to it
any helps appreciated
go to www.muscularmustangs.com, maintenence section, and read the rough idle section , it gives a step by step to testing and fixing your idle and related problems.
KEM Motorworks
Aug 14, 2015 10:13 PM
