help plzzz
ok heres my problem i changed my fuel pumped and my fuel relay but my fuel pump still wont turn on when i turn the key plz help
______________________
1988 5.0, exhaust, pulleys, trick flow intake, 75mm throttle body
you replaced the relay under seat ? or the inertia switch in the trunk ?
if you didn't do the one in the trunk....check the harness connection, pull it off....spray some brake cleaner (tuner cleaner if you have it)
