95 Mustang Smog Pump Removal
I searched and couldnt find any straight up answers to this issue. The pump just seized up on a 95 GT. I am wondering if it is possible to just run a shorter belt and remove all the smog pump stuff. If so does anyone have the part number for the belt or what car it came from? It is hard for me to do any research on it like using a string and just going to autozone and picking through their belt selection because I am on Guam and they really dont carry all that much stuff for Mustangs. Thank you very much. Jeremiah
Unless someone has done this exact same thing, it's gonna be hard to find the right belt without trail an error... i know i had to try several belts on my car until i found the right one... and having done so, i noted the brand and number cuz there arent books that i know of that would be of any help in these situations...
yeah you can do it no probs.
you will have to cap off 2 vac lines w/ rubber plugs. and also cap off the steel pipe that goes to the h-pipe. either weld a cap, flatten it fold it over and jb weld to seal it up (if it leaks, you'll hear the "tick tick tick " of leaky exhaust.
belt sizes run like this........ for a number like gates.... KO60695
the 60= 6-rib
695 = 69 1/2 " belt
with the old belt still in place....to hold the tensioner....run a piece of string around the pulleys , and then go about 1/2" smaller than you measure out.
if you know for sure that the belt sizes are the same for '93 and a '95 i'll give you my belt size (will have to go look)
i have no underdrive pullies, still have ac , removed smog
pm me or e-mail if i don't reply back
the 60= 6-rib
695 = 69 1/2 " belt
i did it, whats this go to and what do i do with the open end? my advice to you is to get the smog pump eliminator kit there only like $60 from ford racing! if you have any other q's just ask!
the stock belt on a 94-95 with A/C, PS, SMOG is a 1045k6 which means 104.5" 6-ribs
the smog removal belt is a 872k6 or 87.2" 6 rib belt
if you wanna bypass the smog AND air conditioning.. get a 805k6 80.5" 6 rib belt
the 94-95 DOES NOT REQUIRE BYPASS OR DELETE KITS
eastexsteve
3.7L V6 Technical Discussions
Dec 4, 2015 05:41 AM
