clutch whining
clutch whining
Soo when I start my car up it makes a wierd squeaky noise. When i very slightly apply pressure to the pedal the squeaking stops. Any idea on how I can fix this or what the problem is?? Thanks
RE: clutch whining
I'm having a similar problem. When I start my car up in the morning (cold, obviously), and as I keep the clutch depressed, there's a loud whining noise coming from somewhere in the trans/firewall area. It sounds almost like a metal to metal sound, and it's a high pitched whining. Once I let go of the clutch, it goes away, and it only seems to do it in the morning when it's cold (or so I've noticed).
I was told maybe a pilot bearing or someother kind of trans bearing. Any ideas?
Throwout bearing?
Throwout bearing?
RE: clutch whining
ORIGINAL: REDS 5.0
Most likely the throw out bearing is toast, and if you pull the trans to repair might as well do a clutch job.
But try adjustin the clutch first... but it's probably throwout bearing...
RE: clutch whining
Are you guys responding to me or him?
I plan on getting a new trans, clutch, flywheel, etc when I build the stroker over the winter. If I just replace the throwout bearing, do you think I'd be alright for a while?
How long do you think it'll hold up right now? Is it serious?
RE: clutch whining
ORIGINAL: Jaggezz
