help please
Old Aug 23, 2006 | 03:21 PM
Idrum88's Avatar
Idrum88
Default help please
my auto tranny seems to be getting a little worn and losing some performance, would switching to some of that trick shift fluid help? would that make a difference?...and should i drain and refill or what? thanks
Old Aug 23, 2006 | 03:25 PM
Steakburger's Avatar
Steakburger
Default RE: help please
Changing the fluid may help mask the problem, but it won't make it go away. Time to swap in a 5-speed.
Old Aug 23, 2006 | 03:34 PM
Idrum88's Avatar
Idrum88
so it wont really make it perform any better?
Old Aug 23, 2006 | 03:45 PM
5.0 MPG's Avatar
5.0 MPG
heat is the #1 enemy of your engine and tranny. do you have a trans cooler?
Old Aug 25, 2006 | 02:22 PM
Idrum88's Avatar
Idrum88
i have not added anything for the transmission does the stock setup not have a trans cooler?
Old Aug 25, 2006 | 05:00 PM
Idrum88's Avatar
Idrum88
and would there be a reason to put a good trans cooler on if the trans might be damaged?
Old Aug 25, 2006 | 08:05 PM
Stevens91gt's Avatar
Stevens91gt
rebuild it
