Head/Cam Job, question...
RE: Head/Cam Job, question...
ORIGINAL: 88stangaruu
Heres a tip...if your just doing a clutch, dont pull the motor. If your doing the H/C/I swap to, id pull the motor and clean everything up, maybe paint the block while its out, etc. That way everythings done and goes back in with one step. I mean if your doing the H/C/I swap, all the fuel lines, wireing harness, etc. all has to come out anyhow so id only pull the engine if your doing it all at once.
Ive done about 10-12 clutch jobs and theyre pretty straight forward. The quickest ive done one is in about 5 1/2hrs and the car was driving down the road. Get a manual, thats always a step in the right direction.
Good luck.
ORIGINAL: OnyxCobra
Well I'm not thinking about pulling the motor to do the clutch, I'm thinking about pulling it for the heads/cam and then the clutch would be a breaze. I am just not familiar with that part of the car...
Good luck.
ORIGINAL: grabbem88
5.5 hours is about right doing a clutch on a tko tanny....that has to be centered just right....
hell it took me an hour to get that stupid cross member on..[:'(]
Its the catted H pipes that aggrivate the **** out of me. [:'(], they're a bitch to get out and put back in with those damn cats on there. With my o/r H pipe i can pull and replace a tranny easily with the exhaust on, with X pipes you have to remove them from what ive found.....
THose cross members are a bitch [:@]
what exactly do you have to unbolt to get the engine off the tranny? with the engine out will it be easy to do the throwout bearing/rear main also? (sorry prolly a stupid question)
just your linkage,sensor or two,speedo cable,and 8 bolts...throwoutbearing is easy just don't try and put it on with greasy hands..broke the tabs once doing that....also change your 15 dollar pilot bearing also..
ORIGINAL: grabbem88
on the tranny..but i was thinking about it sensors stay put...i was thinking if you had to pull tranny come to think of it cable can stay put also...the bolts are what's to the block...
ORIGINAL: OnyxCobra
where might i find said linkage, sensor(s), cable and bolts?
ORIGINAL: grabbem88
09-25-2015 09:06 AM
