its seen better days!
Old 08-24-2006, 06:53 PM
50enzo
50enzo's Avatar
Default its seen better days!
my fifty has bout 135,000 miles on it. its an automatic.what can i do to pep it up w/o rebuilding anything? or is that kinda pointless? money is definitely an issue.
50enzo is offline
Old 08-24-2006, 06:59 PM
88stangaruu
88stangaruu's Avatar
Default RE: its seen better days!
3.73' Gears.
88stangaruu is offline
Old 08-24-2006, 07:00 PM
BlackLX
BlackLX's Avatar
Is that all the mods that you have in your sig? If it is, the first thing I would get is 4.10 gears, shift kit, and a nice stall converter.
BlackLX is offline
Chuy1988
Chuy1988's Avatar
ORIGINAL: 88stangaruu
3.73' Gears.
+1 and stall.
Chuy1988 is offline
Old 08-24-2006, 07:01 PM
88stangaruu
Damn i dont read very good...if its an automatic, go with the 4.10's.
Sorry. [:@]
Old 08-24-2006, 07:06 PM
gspfunk
gspfunk's Avatar
on a budget, the best thing you can do is a full tune up:
Plugs/wires, distributor cap/rotor, oil/oil filter change, fuel filter, K&N panel filter for stock airbox, remove air silencer (google search will find pages w/ instructions and pics), bump timing up a couple of degrees (not more than 12ish w/o using higher octane gas)....all that for starters.
Plugs--Autolite=$1-2 per plug
Wires--FRPP, MSD, Taylor=$35-70/set
Cap/rotor--Off brand, MSD, Motorcraft=$15-25
Oil/oil filter--Whatever oil you use=$8, Wix/motorcraft filter=$8-10
Fuel filter=$10-15
K&N=$40
Total=~$150 or so, depending on the brands you choose.
Some of those can be found at your local auto parts store, some will be cheaper online, but you'll have to wait for them. After that stuff is done, save up a few hundred and get gears. 4.10's since you have a slush bucket AOD....gears will give you the biggest gains speed/time wise.
EDIT: Sorry, I missed your sig....scratch a few of those off the list
gspfunk is offline
PaulH2
20
01-31-2016 09:48 AM
09-27-2015 03:16 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: its seen better days!
