HIGH IDLE!
Old Aug 24, 2006 | 09:27 PM
abrfan's Avatar
abrfan
Default HIGH IDLE!
I recently installed a new upper and lower edelbrock performer intake and i also installed bbk 70mm throttle body and spacer my 5.0 is a 1987 no masss air sensor. My car ran fine before i installed the peroformance parts but after i put it all back together the car idles at approx 3 thousand rpm. I can adjust the timing so that it is at about a thousand rpm but the car will not move it back fires horribly when it does backfire is when its set at 3 thousand rpm if i wanna drop the idle about a thousand without changing the timing i can disconnect the map sensor but all that does is make nothing but black smoke (unburnt fuel) i need help i dont know what i can buy or change or what i should have installed when i put on all the performance parts and i was wondering if anyone had any ideas?
Old Aug 24, 2006 | 09:29 PM
Steeda1716's Avatar
Steeda1716
Default RE: HIGH IDLE!
Sorry i cant help you
Old Aug 24, 2006 | 09:35 PM
titanium92's Avatar
titanium92
Sounds like a vacum leak...maybe the lower intake has a leak.
Old Aug 24, 2006 | 11:01 PM
hellas85stang's Avatar
hellas85stang
use a vacum gauge and check it for leaks...mine did that at idle and my carb was leakin a vac
Old Aug 24, 2006 | 11:09 PM
fassst5.0's Avatar
fassst5.0
you're problem is that you cant do performance mods to a speed density 5.0 without gettting the a/f ratio retuned therefore your car is running like sh*t. soo convert it to mass air
Old Aug 24, 2006 | 11:54 PM
Joel5.0's Avatar
Joel5.0
You can do those performance upgrades, even though it's speed density.....disconnect the IAC and adjust the throttle blade stop screw all the way back.....if the idle speed is still too high, you have a vacuum leak that needs to traced and corrected, or a faulty IAC. If the cam is still the stock one....it's a matter of identifying what's causing the problem. My 2¢.
Old Feb 28, 2007 | 07:40 AM
abrfan's Avatar
abrfan
well its been a long time since this post and i sold the car and got a new mustang lol......that car was a vacume leave...the uppper intake was cracked in 3 places.....guy who bought it put the stock intake and throttle body all back on it and it was faster...realll fast
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
69Volunteer
Sep 30, 2015 10:39 AM
MacSerio
Sep 27, 2015 01:05 PM
