interactive system technocogies
Old 08-27-2006, 01:09 PM
kennebell92conv
kennebell92conv's Avatar
Default interactive system technocogies
just what to tell you 5.0 guys that i got my air adjuster in today when i unpluged my chip from ecu and installed the adjuster on . all the surgeing and bucking at all speeds was fixed you can adjusted a/f to rich or lean it works good
kennebell92conv is offline
Old 08-27-2006, 02:07 PM
will
will's Avatar
Default RE: interactive system technocogies
You removed your chip? Custom tune? Air adjuster works well with stock programming?If so I'm on board!
will is offline
Old 08-27-2006, 02:10 PM
92hatchLX
92hatchLX's Avatar
Can I get some more info about this, maybe a link??? I've never heard of anything like this.
92hatchLX is offline
Old 08-27-2006, 02:13 PM
will
will's Avatar
http://www.mass-air.com/Products.htm Try this...takes a few before it loads slow site
will is offline
Old 08-27-2006, 02:23 PM
92hatchLX
92hatchLX's Avatar
Wow, I've got a pro-m maf and I've got idle issues and I don't think that my MAF is allowing my car to run at it's best. Maybe I should get this before the catback??? From the sounds of it, it's a good machine.
Old 08-27-2006, 03:05 PM
kennebell92conv
my car has 30 psi injecter and 80 mass air sensor now it running on my oe ecu and the air adjuster my chip is not in my ecu
mrtrodonet
09-19-2020 03:12 PM
bradleyb
11-27-2015 07:50 PM
breaking
10-02-2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: interactive system technocogies
