will 351w hold 550-650 hp when stroked to a 408
i plan on getting a 351 w and stroking it to a 408, i also plan on putting a 10 psi blower on it too.
will the 351w hold 550-650 hp.
i seen that the chp shortblocks are like 2599.99-3699.99 http://www.coasthigh.com/Assemblies/Ford/ford_408w.htm
which should i do?
which should i do?
RE: will 351w hold 550-650 hp when stroked to a 408
by the time i buy the kit $1600-2700, get a 351 block say $300-400, get it bored and stroked $600-700
that is all together= $2500-3800 CAD
if i but the short block kit= $3000-4200 CAD
atleast if i buy the short block kit i know i will have no problems with the block spliting if i do i will send it back on warranty.
ORIGINAL: Nadelle
yeah i think so, the 351 blocks are alooooot stronger than the 5.0 blocks, and 5.0 are good untill about 500ish horsepower
ORIGINAL: OnyxCobra
is it really that high? Someone told me their max was around 400-430hp, i would love to know that its 500ish
ORIGINAL: Nadelle
Yep, its about the 500-550 area.
If it was 400-430ish, alot of people on here would be in alot of trouble.
ORIGINAL: 88stangaruu
ORIGINAL: OnyxCobra
ORIGINAL: Nadelle
The Windsors will and can handle that amount of power...if built correctly. If you can, try to get an early block...69-74. These have the most nickel content and a Little more beef in the main webbing area. Run some ARP main studs and a girdle with forged internals and you will be fine. Make sure you have some good breathing heads to go along with it.
ORIGINAL: HaneyMotorsport.Com
^^^ What he said.
nickel makes it stronger and not wiegh as much, i use to have a buick with a 455 stage 1 mostly nickel in the block so it was barely heaveir then a chevy 350 and stronger then a chevy 454..... if only they made cheap parts for it
ORIGINAL: Mustangkiler
Yea, them 455's are exspensive to build, everything is a little higher for them. But damn they're torque power houses. [:@]
