Weight
RE: Weight
Does this sound like a good car? 306CI SHORT BLOCK 1500 MILES ON IT
FORGED SPEED PRO PISTIONS
MOLY RINGS
POWERDYNE SUPER CHARGER 9PSI KIT
TRICK FLOW HEADS JUST REDONE AND RESURFACED
TRICK FLOW UPPER AND LOWER INTAKES
FMS F CAM
1.70 CRANE ROLLER ROCKERS
NEW WATER PUMP
255 WALBRO FUEL PUMP
75MM MAF
42# FMS INJECTORS
MSD 8.5MM PLUG WIRES
AUTOLITE 3924 SPARK PLUGS
CRANE IGNITION
CRANE COIL PACK
BBK SHORTY HEADERS
BBK X PIPE
CATS
FLOWMASTER MUFFLERS
NEW KING COBRA CLUTCH 1500 MILES
PRO 5.0 SHIFTER
ALUMINUM DRIVESHAFT
DRIVESHAFT LOOP
BATTERY IN TRUNK
BATTERY QUICK DISCONNECT NOT INSTALLED
BBK ADJUSTABLE FUEL REGULATOR
FRONT STRUT TOWER BRACE
TRICK FLOW .375” INTAKE SPACER
CUSTOM DIABLO ECM CHIP WITH TUNE
3.73 GEARS
It also is a cobra clone. Thanks, Robert
MOLY RINGS
FMS F CAM
NEW WATER PUMP
75MM MAF
42# FMS INJECTORS
CRANE IGNITION
CRANE COIL PACK
BBK SHORTY HEADERS
BBK X PIPE
CATS
FLOWMASTER MUFFLERS
PRO 5.0 SHIFTER
ALUMINUM DRIVESHAFT
DRIVESHAFT LOOP
BATTERY IN TRUNK
3.73 GEARS
RE: Weight
MOLY RINGS
FMS F CAM
NEW WATER PUMP
75MM MAF
42# FMS INJECTORS
CRANE IGNITION
CRANE COIL PACK
BBK SHORTY HEADERS
BBK X PIPE
CATS
FLOWMASTER MUFFLERS
PRO 5.0 SHIFTER
ALUMINUM DRIVESHAFT
DRIVESHAFT LOOP
BATTERY IN TRUNK
3.73 GEARS
MOLY RINGS
FMS F CAM
NEW WATER PUMP
75MM MAF
42# FMS INJECTORS
CRANE IGNITION
CRANE COIL PACK
BBK SHORTY HEADERS
BBK X PIPE
CATS
FLOWMASTER MUFFLERS
PRO 5.0 SHIFTER
ALUMINUM DRIVESHAFT
DRIVESHAFT LOOP
BATTERY IN TRUNK
3.73 GEARS
RE: Weight
Well let's put this into my perspective. My hatch (with the rear speakers, rear insulation, and spare tire and jack removed) weighs in at exactly 3450 lbs with me and 3/4 tank of gas in it. That means with me out of it it weighs 3270. So I'd assume that yours would weigh in around 3750.
09-08-2015 11:50 AM
