tranny nut size?
Old Aug 28, 2006 | 12:40 AM
Dearborn5.0's Avatar
Dearborn5.0
Default tranny nut size?
t5 manual tranny
what is the size of the nut that connects the rear trans mount to the double hump
cross member.
there are two studs, on the bottom of the rear trans mount that go into slotted holes in the double hump transmission rear cross member.
there are two nuts that fit on these studs. What size are they?
I think they are metric bec some Pr*ck put a 5/16 on there and got it stuck.
that's why out my tranny is listing about 20 degrees to the right.....
Old Aug 28, 2006 | 01:35 AM
Steeda1716's Avatar
Steeda1716
Default RE: tranny nut size?
hahahaha, TRANNY NUT SIZE.....bwahahahahahahaha
Old Aug 28, 2006 | 01:43 AM
BlackLX's Avatar
BlackLX
ORIGINAL: Steeda1716
I laughed too.
Old Aug 28, 2006 | 07:49 PM
Dearborn5.0
punks :P
Old Aug 28, 2006 | 09:25 PM
Boss_Hotrod's Avatar
Boss_Hotrod
I cant remember the size but if its a new ford mount then it will be metic. I dont know about the aftermarket ones. Take a floor jack and place it under the tranny and take the mount out and go to a hardware store and find a nut to fit it.
Old Aug 28, 2006 | 11:55 PM
fordboyyfm's Avatar
fordboyyfm
i know 9 times out of ten they are 18mm. but its been a long time since ive had one out of an older stang. im trying to think of a car/truck that doesnt have a 18mm there. used to pull trans' all day when i was going through school but havent been doing to many latley so i cant really recall.
Old Aug 29, 2006 | 12:03 AM
88stangaruu's Avatar
88stangaruu
the actual bolts that hold the tranny in? Either 5/8 or 15mm from what ive found.
Old Aug 29, 2006 | 03:19 PM
Dearborn5.0
I agree, its a metric thread.
nut size is M-10-1,50
I'm using grade 10 metric bolts (like grade 8 SAE)
Its a 15mm socket
what's the torque spec?
Old Aug 29, 2006 | 03:27 PM
7upedition's Avatar
7upedition
http://www.muscularmustangs.com/2005/torquespecs.php
I'd tighten it as tight as you can get it... and use threadlocker.
Demodulates
Sep 18, 2015 11:14 AM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
