which will make more power?
Old Aug 29, 2006 | 02:28 PM
xtremestang94gt's Avatar
xtremestang94gt
Default which will make more power?
justa wondering which will make more power
afr 165, tfs stage 2 cam and a holley systemax
or
twisted wedge heads fts stage 2 cam and a holley systemax
or should i go with afr 185
Old Aug 29, 2006 | 02:35 PM
Twotone93stang's Avatar
Twotone93stang
Default RE: which will make more power?
oh nevermind um they look all the same power wise. So whichever you like better
Old Aug 29, 2006 | 02:48 PM
r.barn's Avatar
r.barn
they will make about the same power
185's un-needed unless stroking or adding s/c
Old Aug 29, 2006 | 03:19 PM
88BlueGT's Avatar
88BlueGT
I would go with the TW's just because they are a little cheaper and they have tons of room to grow.
Old Aug 29, 2006 | 03:33 PM
P Zero's Avatar
P Zero
+1 on the TFS heads. I like em better than the AFR's. And as for port size, it basically works like this - the smaller the runner the more torque it will produce. the bigger the port the more horsepower. As for which head 165cc or 185cc, its up to you really. 185's would be good if you upped the compression to about 11:1 or if you plan on running your motor to the higher RPMs (7k+), if you plan on leaving it stock then the 165's would do just fine.
-P.
PS: The twisted wedge head has a 170cc runner, and teh TFS high port head has a 192cc runner.
jpplaw
Mar 19, 2025 08:53 AM
Diode Dynamics
28
May 26, 2022 12:02 PM
ShaneB26154
35
Mar 4, 2021 04:05 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
motown girl
Aug 28, 2015 08:21 AM
