what stall?
Old Aug 28, 2006 | 05:18 PM
PX429's Avatar
PX429
Default RE: what stall?
your cam is the most important thing to match up to your Stall convertor. FIND OUT
Old Aug 28, 2006 | 05:28 PM
88BlueGT's Avatar
88BlueGT
WAIT... you already have all of this stuff?
Old Aug 28, 2006 | 05:29 PM
92civy's Avatar
92civy
no this is what i have come up with for the build
ORIGINAL: 88BlueGT
Old Aug 28, 2006 | 05:30 PM
PX429's Avatar
PX429
Did you not say "here is what i got so far"
ORIGINAL: 92civy
here is what i got so far:
408w with afr 205 heads,trick flow r series 5.8l intake, custom cam (not sure what yet), 60 lbs injestors, 255lhp fuel, 90 mm maf, 80mm TB, long tube headers, 12 psi intercooled procharger s/c, i will be running 3.73 gears, and 17x 10.5 back anf 17x 8 front cobra wheel (315/35 17, 245/35/17)
will have drag slick on at track
Old Aug 28, 2006 | 05:31 PM
88BlueGT's Avatar
88BlueGT
OK... thought so.
Like PX said, I wouldnt get a stall until you got the specs on the cam because whoever does your stall is going to need that information from you along with all the other information.
Like I said before, why dont you just go with a beast *** NA motor and save yourself like 4K?
Old Aug 28, 2006 | 05:35 PM
92civy's Avatar
92civy
hydraulic roller cam: 555/570 238/245 50 110*
Old Aug 28, 2006 | 05:36 PM
luckythirteen13's Avatar
luckythirteen13
ORIGINAL: 92hatchLX
Don't ask us, we can't build you one, call up Edge Racing Converters and ask for Andre, he'll set you up.
yep
Old Aug 28, 2006 | 05:37 PM
92civy's Avatar
92civy
i ment to say here is what i have got together but shortened it
ORIGINAL: PX429
ORIGINAL: 92civy
Old Aug 28, 2006 | 05:40 PM
88BlueGT's Avatar
88BlueGT
Just take things one step at a time and make sure that everything is matched up.... also, did you think about what I said?
Old Aug 28, 2006 | 05:41 PM
92civy's Avatar
92civy
no but i might, what do u suppose i do for high hp
ORIGINAL: 88BlueGT
