It really depends man.... it depends on what size tire your running, what gears you are running, your cam, your intake, your heads, etc. Everything needs to be matched up. Also, you dont need a 12psi supercharger to his 600rwhp in a 408. Get a 418W, AFR 225's, a beast cam and beast intake/carb setup and I gaurantee you will come close as hell to that if not hit your goal.
408w with afr 205 heads,trick flow r series 5.8l intake, custom cam (not sure what yet), 60 lbs injestors, 255lhp fuel, 90 mm maf, 80mm TB, long tube headers, 12 psi intercooled procharger s/c, i will be running 3.73 gears, and 17x 10.5 back anf 17x 8 front cobra wheel (315/35 17, 245/35/17)
