Trick flow kit...
#27
RE: Trick flow kit...
Yea ill go ahead and do it all at the same time? Should i get an aluminum flywheel, king cobra clutch, and aluminum driveshaft?
Also is there any reason why i couldnt get the TRACK HEAT instead of the STREET HEAT?
What gains would i get from the track heat?
#28
Trickflow kit will get you in the 12's easy.
slap a little nitrous on there and run high 11's.
You really think that kit makes that much of a difference? I have the kit installed just got to get it all tuned out.
#29
