GT40P Heads problem with plug wire boots
Old Aug 30, 2006 | 01:12 AM
smitty882's Avatar
smitty882
Default GT40P Heads problem with plug wire boots
Having trouble with burning my plug wire boots on cylinder 5 and 6 on my 5.0. The heads I have is GT40P Cast iron heads. The headers I have on are BBK Longtube. I have just bought and installed Trick Flow 10mm Plug wires with 45 degree boots and it didn't look like it was going to hold up but I wasn't sure. I also put the fiberglass boot heat protectors on. It burn't the boot and was jumping spark after about 10 miles. I would like to save my plug wires and try to buy smaller 90 degree boots and connectors for those two cylinders and redo the ends to make them work. I haven't had a chance to look into that option yet. Any one know where. I can find those? Anyone else have any suggestions?
Old Aug 30, 2006 | 02:01 AM
will's Avatar
will
Default RE: GT40P Heads problem with plug wire boots
You can get just the plug wire ends and boots from NAPA, have them go thru their Belden book.
Old Aug 30, 2006 | 02:17 AM
mrbigshot's Avatar
mrbigshot
you need 90 degree ends on those cylinders.
Philhampton1
Aug 21, 2015 12:04 PM
microgt
Aug 20, 2015 07:12 AM
Lazyxdink
Aug 12, 2015 03:39 AM
Pain.
Aug 7, 2015 10:48 PM
