Electrical Problem?? Please HELP!
Old Sep 4, 2006 | 12:01 PM
95Saphire5.0's Avatar
95Saphire5.0
Default RE: Electrical Problem?? Please HELP!
ORIGINAL: leadfootdriver
ORIGINAL: 95Saphire5.0
The TFI modules don't last forever. I had 1 go on my Tempo. While I was driving, the motor just cut out like I turned the key off. Sometimes they go slowly and put out a weak orange spark. The local parts store around here tests them for nothing. Maybe the 1 around you does too. Check it out. Put some dielectric grease on it when you reassemble they new/old one to dissapate the heat.
BTW, you'll need to grind down the proper 1/4 drive deep socket to fit in there, or you can get the tool to remove it.
Is the TFI the same as the "ICM" located on the fender apron?
I don't see anything mounted to the distributor
It might be different with the later 5.0's. On mine it's mounted to the dist. Here's a cool short on how to replace it. There's a pic with the TFI installed at the bottom. http://www.turbotbird.com/techinfo/TFI-PIP/TFI-PIP.htm I did a search on Ford TFI's, and there was a class action suit against Ford because the TFI's were dying all over the place.
From what little I've read, they seem to act up with heat. 'Could be your problem. But like I said earlier, mine died instantly, so you're lucky you haven't been stranded like I was. Here's another quick link. http://autorepair.about.com/library/a/1h/bl926h.htm
Thanks... It is remote mounted on mine. It seems their have been a bunch of different issues related to this going bad. I can pick one up for around $60, so I will get one and see if it makes a difference.
Old Sep 4, 2006 | 12:22 PM
Fox's Avatar
Fox
You might also consider cleaning the MAF sensor elements with electronic cleaner.
Old Sep 4, 2006 | 05:05 PM
95Saphire5.0
Well, I installed a new ICM, and it made no difference... I will keep my fingers crossed that someone has a solution, and continue trying any suggestions.
Old Sep 4, 2006 | 05:29 PM
leadfootdriver's Avatar
leadfootdriver
Sorry to hear that. There's still the "Stator" in the distributor left. I had 1 go bad in my Grand Am. It was a 12 dollar part, and I beat my brains out over it.
Old Sep 4, 2006 | 10:42 PM
95Saphire5.0
Well, that was one of the possibilities that I have not tried. I guess I'll have to try it out.
Old Sep 5, 2006 | 12:35 AM
mpswirl's Avatar
mpswirl
First off does it drop rpms at cruise as well as idle because if it does then it isnt your iac. If the stator doesnt fix it you need to check fuel pressure because the pump might be getting heat soaked and losing pressure. If you have questions test parts just ask because it gets pricey just popping parts in.
Old Sep 5, 2006 | 08:30 AM
95Saphire5.0
ORIGINAL: mpswirl
Yes, it is actually more noticeable at cruise. Is there a simple way to test the pump?
Old Sep 6, 2006 | 11:23 PM
mpswirl's Avatar
mpswirl
You have to connect a fuel pressure guage to it and drive it.
Old Sep 20, 2006 | 12:31 AM
95Saphire5.0
Stator was replaced 4 days ago, and the problem is gone!! $20 part, 2 hours to tear into the distributor, and it's running better then ever. Thanks!
jma2
Jul 10, 2023 01:00 AM
ak98
Feb 18, 2023 08:36 AM
uberstang1
Sep 20, 2015 06:42 PM
ccdguy
Sep 19, 2015 05:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
