clutch question
clutch question
how do u get your clutch pedal to adjust? i was reading in another post that its self adjustable, but dunno how to do it. i may just need to replace the clutch cable but if i can just adjust it, thatd be great. so what do u do? somethin about pullin the pedal all the way up and something w. the hook on the quadrant... idk...can yall help me out? thanks.
RE: clutch question
The auto-adjust feature on my clutch pedal didn't work, so I did the following: Get up under the dash, and put your finger on the hooked part of your quadrant. Then push the clutch pedal down with your other hand. As you let the pedal back up, push the bottom of the quadrant upward, against the force of the pedal returning. If you push it the quadrant hard enough as the pedal returns upward, you'll hear a click. Try to only get one click, as two will probably be too much. You may have to physically pull the clutch pedal back up, if your holding the quadrant hard enough. After it clicks, your pedal action should be a little higher, allowing the clutch to fully disengage.
RE: clutch question
ORIGINAL: dimebag
alright man... thanks alot... ill either go try this tn or wait till tm when its light out... thanks man.
http://www.corral.net/tech/drivetrain/clutcha.htm
RE: clutch question
ORIGINAL: dimebag
hah, just saw it in the other thread... readin it now... thanks alot man... btw i like how ur exhaust is set up.. very unique... nice.
RE: clutch question
ORIGINAL: dimebag
idk... its deff not the norm... id keep it... just cuz its differant.
