Manual Valve Body
Manual Valve Body
I already have a shift kit, but I'm wanting to manually shift it also. I was thinking of going with the Lentech Street Terminator. With the Street Terminator I will be able to manually shift it and I can leave it in drive and it will shift all by itself like a regular AOD right? They have 3 different calibrations, so which one would you recomend?
http://www.lentechautomatics.com/aodproducts.html#
RE: Manual Valve Body
Trans lab is good Talk to Dean he's the owner you can email him at deanmason@juno.com
Maybe I'm missing something, but how is that any different than your everyday AODE tranny with a shift kit? That's no different than what I can do with mine. I can shift 1-2-D or I can simply leave it in D if I want it to shift automatically. It will stay in 1 or 2 unless I shift it myself. To make it a bit easier I got a ratchet shifter just to make sure I don't accidentally skip over a gear when shifting up and down. Unless I'm missing something, this valve body wouldn't change a thing in an AODE tranny with a shift kit.
ORIGINAL: samseed101
ORIGINAL: JD1969
A trans with a manual VB will shift faster and harder than your regular AOD with a shift kit. As far as I know once you to a full manual VB the trans will not ever shift by itself. If you put it in 3rd at a dead stop the car will take off in 3rd.
If he were to go full manual, then it would make sense. But this seems like nothing but a fancy shift kit.
I have a AOD so I really can't really shift it manually like you can with a AODE. If I am right the street terminator will let me shift it whenever I want or I can leave it in drive and let it shift itself.
Ahh...forgot about the limitations of the AOD. It's been so long since I've had a mustangwith an AOD that I got used to the newer style. Guess I should have checked your sig to see the car first to know that it wouldnt have the AODE. Yes, it sounds like the street terminator will allow you to do what you want it to do.
**edit** reading it again...it sounds like it basically turns the AOD into an AODE with a shift kit (complete with electric OD delete.) You should be happy with the results. But i highly recommend a ratchet-style shifter if you're going to shift manually.
ORIGINAL: BlackLX
Do you think the B&M hammer shifter would work good? They're $200 from summit but I found some on ebay for for $190.
I bought mine on eBay too. Absolutely LOVE it and it's relatively easy to install. It looks nice and feels great. Here's a few pics of what it looks like installed in my car. **ignore the stains on the floor mats**
