how much power does it really take to pull up both wheels?
#21
RE: how much power does it really take to pull up both wheels?
ORIGINAL: Tims 88GT
thats not saying anything. sry
ORIGINAL: CT5Ohh
i could do it with my GTO it had about 430hp. I had 90/10 shocks up front and the back shocks and springs were worn out. I would throttle it at like 10mph to get the car rocking then I'd time it and just stuff it. It wasnt anything crazy but they would get a few inches up.
the question asked about power, and its basically the same formula for most cars to get the wheels off the ground.
#23
ORIGINAL: SSKiller
You can set up your suspension to do if with as little as 250 horsepower..............On slicks and leaving on Nitrous I could one off the ground...........
j/k my suspension is set up not to do that.........
#24
no it's tq buddy...a 50 hp car with 500lbs of tq could do it
ORIGINAL: gbtrout
There is no way you can pull both wheels with only 250hp. I go to my local track all of the time and everyone that can do that is pumping out at least 450 hp and has several hundred dollars in suspension mods. I don't care how good the suspension is, it's torque and hp that pulls them
ORIGINAL: SSKiller
#25
ORIGINAL: grabbem88
For the record there's no way you could have 50 hp and 500 lbs of tq.
#26
i guess you never messed with diesel engines have you?....i wonder why i even bother with some of you guy's.....that was a hypothetical number mind you,but if you must know my train switcher is a 400hp engine that makes over 2000lbs of tq....
ORIGINAL: gbtrout
And most cars that have 500 lbs of tq normally have what?.... around 450 hp
ORIGINAL: grabbem88
#27
ORIGINAL: grabbem88
ORIGINAL: gbtrout
ORIGINAL: grabbem88
#28
Yes, you need some power BUT I would have to say that 85% of pulling wheels is all suspension...
I know because I have dont it before. In my 88 with no motor and no trans [8D]
#29
If you put some 4.56 gears or 4.88's in a fox with a big stall or dump the clutch with slicks and have taken 100 pounds or so off the front I'm sure you could pull the the front wheels a couple inches or twist it enough that one wheel comes up off the ground.
