cam?
Old 09-07-2006, 02:37 PM
88stang5.0GT
88stang5.0GT's Avatar
Default cam?
whats the best 303 cam to use in my 91 302
88stang5.0GT is offline
Old 09-07-2006, 02:41 PM
83gtragtop
83gtragtop's Avatar
Default RE: cam?
smog or no smog?
83gtragtop is offline
Old 09-07-2006, 02:54 PM
88stang5.0GT
Default RE: cam?
all emission things are still on the car also i didnt say at first that its an AOD
i think the only one i can use is the e303 but i dont know
Old 09-07-2006, 03:00 PM
Pure5.0
Pure5.0's Avatar
Default RE: cam?
I heard an e303 is emissions legal but also heard there is another that will pass inspection but isn't advertised to do so.....is that a b303 or am i just talking out my ***
Pure5.0 is offline
Old 09-07-2006, 03:02 PM
88stang5.0GT
Default RE: cam?
im not sure but i think you can only use the b303 with a 5-speed cant you?
and yeah the passing emissions thing is making me think that e303 is the way to go
Old 09-07-2006, 03:04 PM
P Zero
P Zero's Avatar
Default RE: cam?
A B303 with 1.72's is basically an E303 with more duration. The E303 has more lift but less duration. AS far as I know neither of these cams would pass emissions (depending on the rest of your setup). But your best bet is go to the Ford racing site and download the PDF file for the catalog, Im sure the smog/emission info would be in there.
-P.
P Zero is offline
Old 09-07-2006, 03:06 PM
P Zero
P Zero's Avatar
Default RE: cam?
ORIGINAL: 88stang5.0GT
You can use any cam with any trans. There are some that are better suited (or suggested) for a particular type of trans, thats because the cams with higher duration have a much lower vacuum signal which could cause some shifting problems with trannies that are vacuum controlled.
-P.
P Zero is offline
Old 09-07-2006, 03:09 PM
83gtragtop
83gtragtop's Avatar
Default RE: cam?
E-303 is smog legal
B-303 is not
Old 09-07-2006, 03:11 PM
88stang5.0GT
Default RE: cam?
well im pretty sure im going with the E303
thanks for all the advice and help
Old 09-07-2006, 03:16 PM
P Zero
P Zero's Avatar
Default RE: cam?
ORIGINAL: 83gtragtop
E-303 is smog legal
B-303 is not
Hmm... must be the duration. Cuz the B cam is under .500 lift where as the E cam is like .530 (or somethin like that). Hey no skin off my back, theres no emisions testing where I live. So you could even runa .700 lift cam and blow black smoke out the pipes and not get pulled over .
-P.
P Zero is offline
Quick Reply: cam?
