Nitrous Knowledge-Please Help!
Old Jul 6, 2004 | 04:47 AM
Disgustang's Avatar
Disgustang
Default Nitrous Knowledge-Please Help!
I have a 1990 5.0 and I am looking into investing in Nitrous, but I do not know much about the diff. brands or anything or the benefits or downsides to the kits and whether or not it is safe for the motor. I was wondering what you guys would recommend in terms of a kit for my car. Dry or wet? How big of a shot can I safely do? Educate me on nitrous please.
Old Jul 6, 2004 | 04:53 AM
D1g1tal V3n0m's Avatar
D1g1tal V3n0m
I ♥ Acer
Default RE: Nitrous Knowledge-Please Help!
ORIGINAL: Disgustang
You can do up to a 150 shot safely on the pre 93 5.0s however with your lack of knowledge I would go no more then 100 until you're familiar with it etc.
I would go with a Nitrous Express or TNT Nitrous kit for your car. Those are the two best manufacturers. Get a wet kit.
For safety you might want to get a new ignition box like the Mallory Hyfire VI which has rev limiter, ignition retard, and window switch built it. You will need a Wide open throttle switch also. This will keep your nitrous as safe as possible and keep you from blowing your motor.
Old Jul 6, 2004 | 01:32 PM
Obsol3te's Avatar
Obsol3te
NO!
DONT GO WET!
gas will pool in your manifold and make it go Boom!
Go dry, its better for the 5.0s for a lower shot anyways.
Old Jul 6, 2004 | 02:20 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Wet or dry, doesn't matter. You only have probs with wet kits when you don't use it right (I.E. pushing the button below 2500 rpms and not at full throttle). With a window switch and full throttle switch the nitrous will only be sent under high vaccum situations, sucking the mixture in at a velocity where its virtually impossible to get puddling.
Old Jul 6, 2004 | 10:29 PM
Obsol3te's Avatar
Obsol3te
K listen to MD
I'm just whatcha call a RELAYER
I relay facts!
That may not always be correct
Old Jul 7, 2004 | 02:15 PM
Deleted User's Avatar
Deleted User
I ♥ Acer
Default [Deleted]
[Deleted by Admins]
Old Jul 7, 2004 | 07:39 PM
WNDSOR's Avatar
WNDSOR
you dont pull any vacuum at WOT
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
