codes 1991 gt
Old Sep 10, 2006 | 01:59 PM
10732gt's Avatar
10732gt
Default codes 1991 gt
reading my codes and i am getting koeo a 31-code a95code and a 96 any ideas
Old Sep 10, 2006 | 02:07 PM
mcfomco's Avatar
mcfomco
Default RE: codes 1991 gt
31 PFE or EVP circuit has intermittently failed below minimum voltage of 0.24 volts.
95 Fuel pump secondary circuit failure. The EEC senses infinite resistance to ground from the fuel pump on the Fuel Pump Monitor circuit.
96 Fuel pump secondary circuit failure. The EEC did not sense battery voltage on the Fuel Pump Monitor circuit.
Old Sep 10, 2006 | 02:10 PM
10732gt's Avatar
10732gt
how do i solve the problems ????????
Old Sep 10, 2006 | 02:14 PM
mcfomco's Avatar
mcfomco
You need to find out why they exist and correct the cause. Why did you check the codes to start with? I'm not trying to be an a** but the more info you provide the better you will get helped.
Old Sep 10, 2006 | 02:22 PM
10732gt's Avatar
10732gt
i was having a problem the car at 4000 rpms would fall on its face and then it would fire but most times would not idel and it would back fire
so i posted it here and most said the fuel pump so i changed it still falls on its face but recovers and stays running. so i read the codes after clearing them drove around
for about 45 minutes and i find these codes cant figure it out the new pump is a bbk 255lph
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
mustangheaven
Sep 29, 2015 11:00 AM
