Fuel Pump running constantly
RE: Fuel Pump running constantly
If you do change the pump to a larger one, you're going to hear it at idle. It's not that bad, but it's just something that you'll have to live with.
If you have the car running and stand behind it, you'll hear it. It's just the vibration being transferred to the bracket. There's a little rubber gasket in between the bottom of the pump body and the bracket that will deaden some of the noise.
- Jeff
- Jeff
i have to replace mine soon also. when i turn on the headlights the car will not run that well. you can actually hear the pump bog down when the headlights come on....going with one from summit for $65 110lph
ORIGINAL: 89regattaLX
yea I've called a shop and plan on having it replaced with in the next couple of days...but it still doesn't explain why my check engine light goes on and off after I reach about 1600 rpm untill I lift off the gas, then it stops going on...any help with that would help too
ORIGINAL: Derf00
That means you have severe detonation. Blinking CEL = Detonation or Misfiring. Have it looked at ASAP. Pull all your plugs to find the bad cylinder and go from there.
ORIGINAL: dillon1340
- Jeff
mine runs in the on position forever even if its not runnng and just in the on position. if its getting loud change the fuel filter. that's what i ended up doing...now im looking at no oil pressure with a clogged oil screen fuel pumps was last months problem lol
A common symptom of a fuel pump going bad is it gets noisey. That doesnt apply to aftermarket pumps because some of them are noisey. I worked at ford as a tech and if i heard the pump i would tell them its probably going bad. Id replce it if i were you becuse getting stranded is not fun.
