Fuel Pump running constantly
Old Sep 13, 2006 | 04:08 AM
89regattaLX's Avatar
89regattaLX
Default Fuel Pump running constantly
My fuel pump constantly runs while the car is running and is very noisy, I know it's not supposed to but does it require replacing or something else...any info will help.
Old Sep 13, 2006 | 04:23 AM
primetime5.0's Avatar
primetime5.0
Default RE: Fuel Pump running constantly
its supposed to run while the car is on...
Old Sep 13, 2006 | 04:36 AM
89regattaLX
ok but I don't remember it ever being that noisy before
Old Sep 13, 2006 | 04:38 AM
PX429's Avatar
PX429
Yeah it shouldn't really be loud, you might look into getting it replaced soon.
Old Sep 13, 2006 | 04:46 AM
89regattaLX
yea I've called a shop and plan on having it replaced with in the next couple of days...but it still doesn't explain why my check engine light goes on and off after I reach about 1600 rpm untill I lift off the gas, then it stops going on...any help with that would help too
Old Sep 13, 2006 | 05:22 AM
PX429's Avatar
PX429
Yeah, ever thought of running the codes?
Old Sep 13, 2006 | 06:12 AM
Liquid_02's Avatar
Liquid_02
Why replace it when it still works? replace it when it stops working... Who cares if it's noisy? Just check the pressure and make sure it's still pumping enough fuel
Old Sep 13, 2006 | 09:55 AM
7upedition's Avatar
7upedition
could be the sending unit, or fuel pump relay,
Old Sep 13, 2006 | 12:15 PM
88BlueGT's Avatar
88BlueGT
They are noisy from the factory but not supposed to be that loud. If you just turn your car one click (not starting the car) you should be able to hear it kick on, etc. but you shouldnt be able to hear it while driving, etc. Atleast I cant.
Old Sep 13, 2006 | 12:39 PM
4fit?'s Avatar
4fit?
If you're going to replace it, just do it yourself. If you plan on increasing the hp in the near future, go with a larger unit like 190 or even a 255 if you plan on some serious fuel needs.
