TPS SENSOR WIRE...
09-15-2006, 11:15 AM
TPS SENSOR WIRE...
to check this tps sensor thing, they say to puncture a hole in the wire, any other better way to do this?
09-15-2006, 11:18 AM
RE: TPS SENSOR WIRE...
take a razor and put a small slit in it for the lead to make good contact then repair with some elec tape or heat shrink
yeah dont do that, use a sewing needle or push pin, the kind grandma sticks in the cotton apple pillow
09-15-2006, 11:20 AM
none the less if i were to go both ways id have to fix it with tape.
09-15-2006, 11:33 AM
true... there always more than one way to skin a cat
09-15-2006, 11:38 AM
hehe it hasnt been moved since 94 and umm car has 190000 kilometers on it. good idea huh
09-15-2006, 11:44 AM
09-15-2006, 12:05 PM
ya i have just the Idle reset and the TPS voltage to do. is the reset necesery? i mena it idles fine it just fluctuates time to time.
09-15-2006, 12:08 PM
it'd be worth fixing, its real easy to do, just make a minimally noticeable cut to the wire
09-15-2006, 12:10 PM
will do. if i can get those screws out, theres the fuel lines in the way.
