help help help 347 problems
Old Sep 15, 2006 | 11:15 PM
Jared_blown5.0's Avatar
Jared_blown5.0
Default help help help 347 problems
hi i just fired up the new 347 combo today and here is my problem. It will surge like crazy and die instantly, or if uyou hold it at 1800 rpms it will run for about 3-5 mins andd then all of a sudden just cut out and die. Right before it cuts out and dies the fuel pressure jumps up. What can i do??????? please help me
-Jared
Old Sep 15, 2006 | 11:41 PM
turbostang21's Avatar
turbostang21
Default RE: help help help 347 problems
what's your fp, inj size, timing?
Old Sep 15, 2006 | 11:43 PM
Jared_blown5.0
38 psi, 42# injectors, 12 degrees
Old Sep 16, 2006 | 12:19 AM
Jared_blown5.0
wow no one?
Old Sep 16, 2006 | 02:05 AM
GaryBisiniere's Avatar
GaryBisiniere
check for vacume leaks and then the timing
Old Sep 16, 2006 | 08:54 AM
88ragtop's Avatar
88ragtop
42# injectors seem like a bit much for your setup.
Old Sep 16, 2006 | 11:13 AM
grabbem88's Avatar
grabbem88
38 psi with vac hose unhooked?.....42's are a pain to tune with stock computer...i run 41 psi with my 24's
given the only diff i see with yours,and mine is 41 cubes your way,and also i have 18* timing.
i'd back off the psi a little,and see what happens...
Old Sep 16, 2006 | 01:27 PM
5.0 MPG's Avatar
5.0 MPG
Id advance your timing a little also.
Old Sep 16, 2006 | 01:56 PM
turbostang21
i'm assuming your maf is calibrated to the 42's...but they are too big unless you're going to boost it. i too would lower the fuel pressure as a start, sounds like it's dumping. what happens if you start the car at wot....
Old Sep 16, 2006 | 02:40 PM
Jared_blown5.0
its not timing, if i start it a wot it hops right up and redlines. lower fuel pressure to say 35?
