help on stroker
RE: help on stroker
Jaggeezz unfortunately, you are actually incorrect. What makes a 347 is a 3.4' stroke with a 4.03 bore. a 342 stroker is actually a 347 but with a stock bore, I should know =) plus with a 3.4" stroke u need to clearance the block, so the rods dont hit =(
RE: help on stroker
If you are starting out with nothing, no intake, no headers, just a wore out 5.0 then yes a 351 is the way to go. If you already have a good intake and exhaust then you are going to have to spend that money all over again. The 351 block is better than a 302, so you will have a stronger foundation to work from. Also to keep your current acessories you are going to have to buy different brackets. How fast are you trying to go anyway?
RE: help on stroker
To use a 351W engine you'd need the following.......
Headers
Oil Pan
Intake
Distributor
And that's just the stuff that comes to mind..
So it's not really a just 'slam it deal'
I think that a 351W complete is about 50# heavier than a 5.0
Also, could somebody tell me why a 351W block is 'better'?
Headers
Oil Pan
Intake
Distributor
