Engine Code 32 Pulled, what should I do?
Old Jul 13, 2004 | 05:41 PM
22Stang's Avatar
22Stang
Default Engine Code 32 Pulled, what should I do?
Hey guys,
I pulled the computer codes of my 92LX5.0 and got code 32 doing the KOEO test.
The code says the EVP Sensor circuit is low. I changed both the EGR and the sensor and it still has the code. I also did a voltage check with my DMM and it checks out fine. I am getting kinda frustrated with this, what should I do to get this to go away/fix.
Anything would help if you have it.
Thanks
Old Feb 25, 2005 | 10:51 AM
quantum555's Avatar
quantum555
Default RE: Engine Code 32 Pulled, what should I do?
I just took mine to autozone because i was getting an intermittent check engine light under light throttle. They stuck it on the machine and pulled a stored engine code 31, whick is "below min voltage" on the "evp sensor". Is there a way to clear the stored engine code. It might still be on for you even though the problem is fixed.
djbigskrilla
Sep 20, 2022 01:04 AM
bryan616fl
Jan 25, 2019 09:07 PM
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
Scottyboy187
Nov 5, 2015 04:18 PM
mweiland
Aug 13, 2015 05:11 PM
