Will the Trick flow package work with...
Old 09-19-2006, 06:24 PM
Chuy1988
Chuy1988's Avatar
Default Will the Trick flow package work with...
I wanted to know if the Trick Flow kit would work with a 331 stroker or the 347??? Just curious to know. Thanks!
Chuy1988 is offline
Old 09-19-2006, 06:26 PM
ooticamitica
ooticamitica's Avatar
Default RE: Will the Trick flow package work with...
if its a bored out 302(what i think sorry im dumb) yea they should work but pry would need to be port polished.
ooticamitica is offline
88BlueGT
88BlueGT's Avatar
Yes, the TrickFlow kit would work very well with a 331 or a 347
88BlueGT is offline
Old 09-19-2006, 06:29 PM
7upedition
7upedition's Avatar
yes yes yes it will be a great top end kit for a stroker motor... and yes a 331 and 347 are 302 blocks.... bored and stroked
7upedition is offline
Old 09-19-2006, 06:30 PM
mattkoly
mattkoly's Avatar
+1
mattkoly is offline
Old 09-19-2006, 06:34 PM
Chuy1988
Chuy1988's Avatar
So the cam that come in that kit would be fine the with the 331 or the 347?
Chuy1988 is offline
Old 09-19-2006, 06:36 PM
Chuy1988
Chuy1988's Avatar
^^ The reason I ask cause they did that package with a 306 stroker and got 350 HP. I was just curious due to the bigger stroke if it would need a different cam with different specs for the 331 or the 347.
Chuy1988 is offline
88BlueGT
88BlueGT's Avatar
To be honest, I would get a custom grind. It will work but its not going to bring out the best of YOUR motor like a custom grind would...
88BlueGT is offline
Old 09-19-2006, 06:37 PM
Chuy1988
Chuy1988's Avatar
ORIGINAL: 88BlueGT
That what I thought?? So what about the heads??
Chuy1988 is offline
Old 09-19-2006, 06:42 PM
88BlueGT
88BlueGT's Avatar
The heads will be fine also.... they will not bring out the best in your motor BUT they will do the job. Exactally what heads are you looking at? the Twisted Wedges?
88BlueGT is offline
Quick Reply: Will the Trick flow package work with...
