knock sensor question
Old Sep 20, 2006 | 07:38 PM
PX429's Avatar
PX429
Default RE: knock sensor question
..send me a picture of this knock sensor you found
Old Sep 20, 2006 | 08:27 PM
JohnnyK's Avatar
JohnnyK
Ditto.. on the intake manifold?!!
Old Sep 20, 2006 | 11:29 PM
Joel5.0's Avatar
Joel5.0
ORIGINAL: jockoal
I checked with ford and found indeed my vehicle uses a knock sensor..it is located on the right rear of the intake manifold....1987 mustang 5.0 h.o. with aod trans..when i had the engine changed i also changed intakes, i asked to have my original manifolds returned..upon inspection today i found the sensor still in my original manifold in the right rear location..i did not know until today that this was the knock sensor, since most knock sensors are located on the side of the engine block.....know i only have to find the computer wire and attach hopefully the sensor is still good, if not buy new no big deal..if anyone knows what the wire color code from sensor to cpu, would appreciate data, as i think they may have snipped it when changing components...its good news anyway as know i know why engine power has been so poor at higher speeds..cant wait to hear an engine ping..al
.....again, here is the '87 5.0L EEC-IV diagrams.....manual and AOD...
Enjoy!......
Old Sep 21, 2006 | 12:20 AM
jockoal's Avatar
jockoal
i made an error on the location of the sensor,its located on the left rear of intake not right..if anyone has a 1987 mustang 5.0 h.o. please let me know what color wire fastens to the knock sensor..thanks: al
Old Sep 21, 2006 | 03:53 AM
JohnnyK's Avatar
JohnnyK
Dude, there is no knock sensor!
Old Sep 21, 2006 | 04:05 AM
PX429's Avatar
PX429
read
ok actually this proves nothing, but the fact that someone still owes someone an f-ing cookie![:@]
Old Sep 22, 2006 | 12:38 AM
jockoal's Avatar
jockoal
UPDATE: I CALLED FORD AGAIN REGARDING KNOCK SENSOR AND AGAIN I WAS TOLD THAT INDEED MY VEHICLE DOES USE A KNOCK SENSOR, PART# E3AZ12A699A.. I WAS STILL NOT SURE WHICH WIRE TO USE, BUT I THOUGHT IT WAS THE ORANGE WIRE THAT THE SHOP HAD NOW GROUNDED TO THE FIREWALL..WITH KEY ON ENGINE OFF I CHECKED VOLTAGE AT THE ORANGE WIRE,SURE ENOUGH IT READ 4.66 VOLTS.. WITH THIS NOW IN MIND I INSTALLED MY OLD SENSOR IN LEFT REAR ON LOWER MANIFOLD..FIRED UP ENGINE AND A NEW SOUND EMITTED, A LOWER MORE INTENSE SOUND, NOT THE FLAT BLAWP-BLAWP SOUND OF PRIOR..YET TO ROAD TEST..AL
Old Sep 22, 2006 | 01:10 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
DUDE! lay off the caps, it makes your post very hard to read and is considered very bad manners on a web board.
Old Sep 22, 2006 | 02:59 PM
Joel5.0's Avatar
Joel5.0
.....Please?
FYI:
Code:
E3AZ12A699A  $81.38 $0.00 $63.48
 Electrical - Powertrain control - Knock sensor
 KNOCK SENSOR, E150-350 Vans, 5.0L 1992 - 1996
Old Sep 23, 2006 | 05:20 PM
jockoal's Avatar
jockoal
Will comply with cap locks off..thanks
