HEADER TEMP
HI WHEN I START UP MY 93 LX AND RUN IT FOR ONLY LIKE 2 MINUTES THE HEADERS SEMM TO HEAT UP QUICKLY, I CHECKED THE TEMP OF THE A COUPLE INCHES BACK FROM THE FLANGE THE TEMPS VARY FROM 190 DEGREES TO 280 DEGREES, IS THIS NORMAL OR DOES THIS MEAN THAT THE CYLINDERS ARENT FIRING EVENLY, THANKS A LOT GUYS
Well heres what I think, this might not be right but it is just an observation.
The inner 2 cylinders are surrounded by a cylinder on each side. The outer 2 cylinders only have one cylinder adjacent to it. Result might be that the inner 2 cylinders will feel some of the heat generated by the outer 2 cylinders but the outer 2 cylinders will only feel heat from a SINGLE adjacent cylinder. Which is maybe why the inner 2 could be hotter than the outer 2. I guess...[&:]
junior04
Sep 28, 2015 10:53 AM
