header/steering problem.....
Old 09-21-2006, 12:33 AM
hearthe5ohroar
hearthe5ohroar's Avatar
Default header/steering problem.....
Someone has had to have run into this problem, let me know how to fix it......
I installed some BBK equal length shorty headers into the ol 5.0. It was an 88 LX 4cyl previously, but it has been converted over to the 302. Anyhow, once i installed the headers, there's this horrible rattle in my steering because of the headers rubbing my steering rack (the bar that comes from the firewall to the axel). Previously, someone told me to put washers under the motor mounts to get enough clearance, but then it just felt off balance and was messing with the feel of the tranny when you went to 2nd gear..... so here i am again, seeing if anyone else has seen or heard of this problem...... Everone else seems to not ever have a problem after they are installed, it's just getting them in, as usual..... any help??????????
PS/ rattle goes away if you lift up hard on the steering wheel or accelerate hard enough to twist the motor away from the drivers side.
hearthe5ohroar is offline
Old 09-21-2006, 12:47 AM
hearthe5ohroar
Default RE: header/steering problem.....
bump
Old 09-21-2006, 03:51 AM
hearthe5ohroar
soooooo, no clue???????
Old 09-21-2006, 01:51 PM
ttoppedaerocoupe
ttoppedaerocoupe's Avatar
ive never heard of anyone having any problems with washers under the motor mounts. I guess step two would be replace the stock mounts. You sure as hell cant move the headers, and rerouting the steering column is going to be a pain in the ***.
ttoppedaerocoupe is offline
Old 09-21-2006, 02:10 PM
fastfox86
fastfox86's Avatar
The only thing I've ever seen done is people notching th column slightly where they rub. Other than that I don't know if thee's much else you can do. I actually have the same problem right now, but it's barely noticeable.
fastfox86 is offline
RichM1983
02-08-2013 10:17 PM
rleey07
08-16-2010 08:31 PM
kane1983
4 Cylinder NA and Turbo
03-05-2010 10:32 PM
cruiser
03-14-2008 08:23 PM
4wheelkillr
10-22-2006 02:45 PM
Quick Reply: header/steering problem.....
