t/b and MAF size
RE: t/b and MAF size
ORIGINAL: gspfunk
Stock MAF=55mm
Stock TB=60mm
Your throttle cable hooks up to the bottom of the TB, not the EGR spacer. I wouldn't remove the spacer unless you do away w/ the entire EGR system.
Stock MAF=55mm
Stock TB=60mm
actually the stock tb size is more like 58mm. and if you remove the egr spacer your throttle cable will hit because its not enough room, you can make it fit though, im doing it next weekend when i install my edelbrock n all that crap. i have a egr eliminator made by steeda from 50resto. i did away with the smog pump, and the hoses, and im going to buy the plug to sit in the egr thing to keep my CEL from coming on.
ORIGINAL: 91stang
where are you moving the throttle cable to?
foxtrot
09-29-2015 06:32 AM
09-25-2015 06:30 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
