oil pump drive shaft fell into oil pan now what?
Old Sep 21, 2006 | 10:56 PM
junkstang's Avatar
junkstang
Default oil pump drive shaft fell into oil pan now what?
i was trying to put a new distributor into the car and it was really hard going in, so i pull it back out and i hear a clink type of noise, i lookin and the oil pump drive shaft lifted up and fell into the oil pan! How do i fix this? do i have to pull the motor? or can i just lift the motor up a few inches and pull the pan and fix this? thanks
Old Sep 21, 2006 | 11:02 PM
jzgt's Avatar
jzgt
Default RE: oil pump drive shaft fell into oil pan now what?
Yeah, you're going to have to pull the pan. Did you not have the star washer on the OP driveshaft?
- Jeff
7upedition's Avatar
7upedition
you'll have to jack the motor using a cherry picker since the jack cant go on the oil pan, and then drain the oil, pull the pan, fish out the shaft, and reassamble.... thats too bad man!
PONY GUY's Avatar
PONY GUY
yeah you can take the pan off and fix it re prime the oil pump b4 u put the distrubtor back in
Old Sep 22, 2006 | 12:34 AM
nmerrill's Avatar
nmerrill
oh man, same thing happened on my bronco. I just unbolted the oil pan, but i dont know if you can do that on a stang
Old Sep 22, 2006 | 07:10 AM
tuff5liter's Avatar
tuff5liter
that really sucks....but while its off you might want to go ahead and get a melling high volume oil pump on it and put a reuseable one piece gasket on the car.....you can get the melling oil pump at autozone for like $30 and it even comes with a new oil pump driveshaft with a star washer so this wont happen again :-) Kinda hard to go wrong for $30 since you have to pull **** apart anyway.
Old Oct 9, 2007 | 05:14 PM
aode08's Avatar
aode08
i was able to get mine out by draining the front sump's oil and using a magnetic antenna in the hole from the obolts goes to drain, its in the front sump, magnet on its face and out she comes.
Old Oct 9, 2007 | 05:41 PM
ahittz24's Avatar
ahittz24
ORIGINAL: tuff5liter
Thats an excellent idea, that way when his motor starts to use oil and gets 1 to 1.5 quarts low and he revs to 6k it will pump the pan dry and it will be rebuild time. HV pumps are made for use on larger pans, ie. 7qt pans. Just get a new pump since your in there (stock volume) and a nice ARP pump shaft and one peice Oil pan gasket. $55 total and you have a new pump, no leaks, and insurance on no twisted/broken shafts.
Old Oct 9, 2007 | 08:41 PM
JohnnyK's Avatar
JohnnyK
Agreed on the high volume pump. Bad idea.
Before you do anything, I would get a long wand magnet and try to fish it out from the top (Who knows) or drag it along the bottom of the pan and get it out that way.
Old Oct 9, 2007 | 09:11 PM
OnyxCobra's Avatar
OnyxCobra
Oh geez, many people including myself run high volume oil pumps with stock pans with zero problems. It's not like its WAY higher volume and is going to suck your pan dry, it's about 25% more I believe.
