HARD STARTS NEED SOME HELP
this is doing it out of the blue.and i'm thinking it's my meter..
driving around is agravating at times idle fluctuates all the time.
i tried to start it this morning and it will start then die...i unplugged mass air meter then it starts...i know what this does,and most likely something is wrong...
i have cleaned everything,and pretty much tested everything also...any idea's where else to check..
RE: HARD STARTS NEED SOME HELP
is it only when starting it, or does it bounce around all the time? is it every time you start it or like the 1st start of the morning? if you unplugged the maf and it did ok, that could be the culprit, but also, when the computer sees no maf reading, it goes into a default, which could be kind of bypassing the actual prob that could be somewhere else, its very tricky. when the maf is disconnected, the comp relies on i think the tp sensor to keep it going
