whats a good mach with afr heads????????
09-23-2006, 04:00 PM
RE: whats a good mach with afr heads????????
Do you want something with a rough idle or something that actually gives you power?
09-23-2006, 04:02 PM
would like a rough idel but whant to make some power
09-23-2006, 04:05 PM
a rough idle cam means it wasn't matched,a fuel injection car doesn't idle a "cam" like a carb set up does.
track heat or a rpm II would be great with a 274 grind cam...upgrade springs btw
09-23-2006, 04:06 PM
not good with cam what is 274 grind cam??
09-23-2006, 04:08 PM
Actually I'd probably go with a 281HR from comp cams
but call them up. they will tell you what cam to use
comp cams part number...
09-23-2006, 04:09 PM
ok thanks for advice
crap...he's running the happy juice get a nitrous cam for it,and you'll get that "rough" feeling that you want.
09-23-2006, 04:13 PM
Quote:
ORIGINAL: grabbem88
I missed that part too.
+1 get a nitrous cam
09-23-2006, 04:15 PM
sounds like you have a good set-up...very good...i know it is costly,but i'd get a custom cam...possible?
