whats a good mach with afr heads????????
Old Sep 23, 2006 | 03:22 PM
jays89gt's Avatar
jays89gt
Default whats a good mach with afr heads????????
whats a good intake upper and lower to work well with afr heads??? also what cam works well
Old Sep 23, 2006 | 03:44 PM
PX429's Avatar
PX429
Default RE: whats a good mach with afr heads????????
...[&o]
What AFR's
What are your other mods? What size gears do you have, are you 5spd or Auto? if auto what stall converter....
We need more info!
Old Sep 23, 2006 | 03:53 PM
grabbem88's Avatar
grabbem88
well afr recomends rpm/victor intakes,but trickflow are good...
Old Sep 23, 2006 | 03:55 PM
jays89gt's Avatar
jays89gt
afr 165cc its a 5 speed 3.73 gears what to go with 4.10 need to know what cam and intake will work good,70mm tb,76 mm maf calibrated for 24lb injectosr ,255lph fuel pump,125 shot of nos
Old Sep 23, 2006 | 03:56 PM
PX429's Avatar
PX429
do you have 24lb injectors?
Old Sep 23, 2006 | 03:57 PM
jays89gt's Avatar
jays89gt
yes
PX429's Avatar
PX429
TrickFlow Track Heat would probably work best
as for the Cam are you looking to passing smog?
Old Sep 23, 2006 | 03:59 PM
jays89gt's Avatar
jays89gt
no i removed smog pump and all hardware
92GreyGT's Avatar
92GreyGT
I use the Track Heat intake and a Comp Cams XE274HR, but I have a 331.
jays89gt's Avatar
jays89gt
kinda want a rough idel cam
