whats better
Old Sep 26, 2006 | 12:40 AM
88stangaruu's Avatar
88stangaruu
Default RE: whats better
ORIGINAL: 91lxstang
im bettin i can easily get low 13's with afr 165's.... trickflow street heat intake... tfs1 cam..... bbk 255lph fuel pump... and 3.73 gears in a 5 speed hatch
Oh yea, no problem there. Id got with a track heat intake though, mind as well...because your going to want to go faster eventually. So that'd be thinking ahead. Keep you from buying something twice. But thats just me.
Old Sep 26, 2006 | 12:46 AM
sick95gt's Avatar
sick95gt
the supercharger would be cool, but you will be limited if you want more boost without the supporting mods. I would do the h/c/i and get the same power as the s/c and if you want more, do the supercharger later.
Old Sep 26, 2006 | 04:10 PM
91lxstang's Avatar
91lxstang
im thinkin h/c/i is the better route and i can hide it from my dad easier ..... the trackheat intake sounds better too........ im thinkin i can put 320 rwhp don with this combo and the other small supporting mods like cai, tb, maf and so on
Old Sep 26, 2006 | 04:13 PM
FullAuto's Avatar
FullAuto
ORIGINAL: 91lxstang
I think that's a little optimistic with that cam choice.
Old Sep 26, 2006 | 04:20 PM
91lxstang's Avatar
91lxstang
hey i have to set a goal, right? what cam would you reccomend?
Old Sep 26, 2006 | 04:45 PM
88stangaruu
you want 320, your going to need a bigger cam. But its doable. Just gotta put your parts together correctly.
Just remember, a bigger cam merits bigger intake and heads for it to breath. But 165's are fine, no need to go bigger unless your going to stroke it.
Old Sep 26, 2006 | 05:12 PM
91lxstang's Avatar
91lxstang
what cam do you guys reccomend? sumthin like tfs2 cam or one of the ford cams?
Old Sep 26, 2006 | 05:24 PM
88stangaruu
Try a Comp XFI cam....lol...that would be great [sm=badbadbad.gif]
Nah, try one of those Comp XE or whatever they're called, their in the 550ish lift area. That would do you some good. But good luck with stock pistons.
Old Sep 26, 2006 | 05:33 PM
91lxstang's Avatar
91lxstang
now i see what u were sayin earlier about runnin stock pistons...... would my combo work with the tfs1 cam, but it just wont be as powerful as it could be?
Old Sep 26, 2006 | 05:38 PM
SSKiller's Avatar
SSKiller
if you plan on supercharging it later, then i would run the AFR 185 heads...........just my 2 cents
